A question and comment on Raptor 660.
First off my question is this, back in August I had a fairly bad crash were I had to replace the right a-arms, rims, and weld the frame where the bottom right a-arm mounts up. I have everything fixed now, new a-arms, rims, and so on. Though once it is complete, the wheel sits on more of an angle then the left side like (|) (\) just not that extreme, is there a way i could have bent where the a-arms and hub bolt to? The frame doesn't look tweaked or bent at all, everything lines up fine, the wheel doesn't wobble when drivining, all in all I am happy with it, just a friend pointed it out when we went riding today.
My comment is if anyone was wondering the result of my running a 15t front sprocket on my Raptor, that has just a pipe, filter, and jet kit, it is awesome, I haven't topped it out yet, because the roads are pretty icey where I am, but in no way does the stock engine struggle to turn it, just now when I raced my friend on his Z400, I can stay in 4th and pull away from him when it is tapped out. [img]i/expressions/face-icon-small-happy.gif[/img]
I'll try and take pictures of it tomorrow to show you what the wheel is like. When I checked the frame over, before and after for many an hour, I couldn't find a bend, I measured distanced between the welded side, to the fine side, and so forth. Maybe pictures might help.
Hey Jibrille, Just a thought, but wasn't it you that said just three days ago that it was good for the boy at Dumont to get hurt and be put into a wheelchair for his own stupidity? Now you need help fixing your bike for your stupidity? Quite a contradiction, don't u think? Here
shav0 and duke, it isn't that kind of alignment, it seems that one mounting bolt for the bottom a-arm slipped out some causing it to push out, the problem is fixed now. [img]i/expressions/face-icon-small-smile.gif[/img]
08-21-2015 01:23 PM
