YFZ 450 jetting
YFZ 450 jetting
I am asking this question for a friend of mine that just bought a YFZ 450 as well as a Trinity full exhaust. I know he'll need to go up on jetting and I'm assuming he'll need to bump it up at least 2 main sizes but he doesn't think so....I ride a banshee so I'm not too familiar with four strokes and their jetting needs. Can anyone tell me about where he should start with his jetting (with the exhaust) on his 450? Any help is greatly appreciated!!!
YFZ 450 jetting
Stock jetting is as follows.... pilot-42, main 158, stock needle is at 4th clip. YFZ's come lean from the factory. Make sure you use Keihin jets, remove airbox lid and I recommend getting the NCVQ needle. Try 45 pilot, 172 main and ncvq needle at 4th clip. If it pops on decel your too lean. If it cuts out or backfires on acceleration your too rich. You will also want to get a zip-ty. for your fuel screw. That will need to be adjusted for smooth idling. YFZ Central has alot of great information for this bike and jetting specs for different pipes at different altitudes and temps.
