banshee only one side running?
Old Nov 15, 2004 | 07:12 PM
kdog's Avatar
Default banshee only one side running?
Hey all you banshee riders. Friend of mine has modded banshee,vito key,timing plate etc,ricky stator,toomeyetc. it runs on only one side till higher rpm then it starts to run the other side. any idea what we should look at??? I have no ideas on bashee as I ride LT250R but I thought i would try and help him. if you got ideas let me know so I can help him and we can go riding.
thanks,
my fellow riders no matter what color you ride.
K-dog
Old Nov 15, 2004 | 11:26 PM
kdog's Avatar
bump....
no one has any ideas for me to check?
k-dog
Old Nov 15, 2004 | 11:53 PM
RoostinOnYou's Avatar
Maybee pilotjet needletube etc clogged up on carb?? Try cleaning carb. Check compression on that side? Look @ reeds on that side might be dumping so much fuel in its blowing out fire till higher R's. If its on left side could be stator going out or weak spark check cdi and stator. Plenty of things it could be on a banshee
Old Nov 16, 2004 | 12:22 AM
kdog's Avatar
thanks for the tips Ill check that stuff.
k-dog
Old Nov 16, 2004 | 02:09 AM
blindside350's Avatar
How old is the engine? Thats how ours was running. My guess is that the rings were broken and as soon as the 1 cylinder started to heat up the other cylinder... We had to get a whole new top end which is totally normal... teh engine was 6yrs old
Old Nov 16, 2004 | 10:35 AM
garyc660R's Avatar
Seems like carb trouble on the side thats not running at low RPM's.....possible slide issue as well.
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
WilliamBos
Sep 30, 2015 08:08 AM
Timjunior
Ask the Editor
May 28, 2015 01:09 PM
B4NSH333
May 26, 2015 06:55 AM
