Good Porting
Old Nov 17, 2004 | 08:25 PM
enFORCER's Avatar
Default Good Porting
RDZ racing is claiming to have the 1st triple port 350 Banshee making 105 hp.....
Old Nov 17, 2004 | 08:27 PM
DaBeechMan's Avatar
rdz claims a lot of things
Old Nov 17, 2004 | 10:06 PM
wannabearider's Avatar
who and where is patriot??? how do i get ahold of them??
Old Nov 18, 2004 | 12:41 AM
roosthrower's Avatar
What's the name of the guy that left MPracing to start his own thing? From my understanding, he's on the west coast and does a damn good job. Dave Moore if I can remember correctly.
Old Nov 18, 2004 | 01:24 PM
  #15
AlkyBurninX's Avatar
DaBeechman, like I said YOU would know who I was talking about. I wasn't going to knock him because he builds some fast stuff, I was just comparing 2 +4 TT/ST motors from 2 builders.
A 95HP 350 isn't for normal use. I race 3/8-1/2 mile tracks for 8-10 laps each for practice, heat, and feature. I usually run at least 2 classes. TT/ST is full throttle then sudden shutdown then full throttle again over and over hitting the overrev on every straight. The motor is bulletproof other than the bearing which isn't the builders fault. I can run a whole season of racing at least once sometimes three races a weekend without teardown. I consider that dependable.
Old Nov 18, 2004 | 06:33 PM
  #16
DaBeechMan's Avatar
as long as you are happy with your build and power that is really all that matters. There are many many reliable 90+hp banshee's. None of which are practical because they are on methanol. But i do know many 75+ gas banshee's still on stock stroke.
Good to hear its running well.
Old Nov 19, 2004 | 01:17 AM
  #17
homdaddy's Avatar
give DTR a call they are in salem . MP is in your area . lrd is in wilsonvile . holeshot in vancouver he does alot of other shops work and they put their name on it like topdog white knuckle and alot of the others around here
Old Nov 19, 2004 | 01:21 AM
  #18
DaBeechMan's Avatar
chad doesnt do eric's work. Not sure who told you that but talking that kind of s*hit will get you're a$$ kicked if you are in the local area
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
cornermike
Jul 8, 2015 11:44 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
