ATV Snorkels, Where can i get them and how much r they???
Old Nov 22, 2004 | 08:54 PM
7QuadSport7's Avatar
Default ATV Snorkels, Where can i get them and how much r they???
i want a snorkel for my eiger, does any1 have a link to a page where i can get one and i heard they take rob hp and different stuff is this true
Old Nov 22, 2004 | 09:24 PM
no1
Old Nov 23, 2004 | 11:14 AM
1ShotScott's Avatar
you will most likely have to make it. if you you use a good strong plastic flex tubing to go from the air box to right under the front rack (or even to the fender but it does not lood as good, then from there use pvc to bring it up through the front rack make sure you put a candy cane bend (90 degrees bend) at the top of the pcv. make sure that you dont have any leaks. a good wath to do this it puy putting a plug on the end of the pipe(don't use glue on the plug) then drill a hole i the plug screw a air compressor hose (with the compressor) in the hole might want to use some plummers tape around the threads. then get a spray bottle put some soap and some warm water in it then spray it at all the fitings of the pipe, this includes at the air box. turn the compressor on DON'T USE MORE THAN 5psi after there is a little air preasure in the pipes whach all the fittings and if bubles start forming then put glue uer that area. after you are done make sure you take the cap off. make sure that you use PVC cleaner, primer and glue, in that order on all the fittings. because you would not like it to fall apart in the middle of a pond from being jerked around. beleive me I know PVC check out my site and you'll see PNEUMAITC SPUD GUNS
oohh and I almost forgot secure all the peices to something sturty like the frame you could use zip ties. you may want to put some heat sheild stuff on the pipe if it comes close to the engine.
Old Nov 23, 2004 | 06:06 PM
do u have a pipe on yours???
Old Nov 23, 2004 | 06:15 PM
TrailBlazerguy250's Avatar
7,so u r getting rid of the honda ?
Old Nov 23, 2004 | 08:30 PM
yea i think i am. tommorow after school were going to go get the eiger but iam still not positive
Old Nov 24, 2004 | 01:14 AM
Jibrille's Avatar
I think you just need to fab them up yourself. Just definately don't rush the project.
Old Nov 24, 2004 | 01:19 AM
great news man , i might be doing a snorkl project on the ol kodiak soon , thanks for the info on it lol
Customer Service #1
May 15, 2020 08:46 AM
Steeldon
Sep 9, 2015 09:38 AM
switzomatic
Aug 24, 2015 12:57 PM
Ean
Aug 20, 2015 07:13 AM
Cantbuytime
Aug 17, 2015 06:33 PM
