warrior over heating
Old Nov 22, 2004 | 11:24 PM
Leroy252's Avatar
Default warrior over heating
My friends warrior is over heating. The bike is completely stock has changed nothing but the oil and plug. Low hours on the motor. Not sure last time the valves were adjusted. Any info or direction to look would be greatly appreciated.
Old Nov 22, 2004 | 11:26 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
invest in soem air scoops.. hhmm how long is he riding?? and in what conditions?? that seems odd...
Old Nov 22, 2004 | 11:30 PM
Leroy252's Avatar
he has been riding for along time and mostly woods and rock quarry. not sure if air scoops are whats needed here the bike never had this problem till today. and nothing has been changed. oil and air cleaner were just changed about a week ago.
Old Nov 22, 2004 | 11:32 PM
Speedy2222's Avatar
sice his legs are mostle likely tucekd up against the enginge it';s trapping heat.. ari scoops will draw mroe air at low speeds... hhmm not sure tho..
Old Nov 22, 2004 | 11:43 PM
TrailBlazerguy250's Avatar
never have herd of this happening, have him ride it faster and not slow, see what it does
Old Nov 23, 2004 | 12:39 AM
Doctorturbo's Avatar
GOT BOOST!
How do you know it's over heating? If the pipe is red hot check the valves. A tight valve will cause a hot pipe.
Old Nov 23, 2004 | 07:26 PM
Leroy252's Avatar
I am pretty sure the bike is over heating, because I used to have a warrior and it never got this hot. Even in the summer. My best guess is the valves are out of adjustment to far. I was hoping someone could shed some light on the situation. thanx for the help guys
Old Nov 27, 2004 | 02:20 PM
VelociRaptor350's Avatar
Throw an oil cooler on it, some of the utility 350's have the filter plate already set up for a cooler and it will fit the warrior, then just buy an oil cooler from summit racing or jegs and hook it up.
Old Nov 27, 2004 | 02:23 PM
7QuadSport7's Avatar
how would you do that???
Old Nov 27, 2004 | 02:27 PM
What, run a cooler?
