air fuel question
Old Nov 26, 2004 | 07:13 PM
whseddon1's Avatar
Default air fuel question
is there a tool i can buy to test the air fuel ratio for my banshee
Old Nov 26, 2004 | 07:32 PM
Shav0's Avatar
Yes. You can get a EGT guage, (exhaust gas temp guage.)
A EGT guage works on utilizing the exhaust to tell you if your mixed lean, or rich. A small sensor has to be installed into your exhaust pipe header by drilling a hole and then inserting this sensor. It also comes with a plug that you can put in there when your not using the sensor. Your Exhaust should be within a certian temp range at each throttle opening.
1/8 Throttle _____750 - 850 Degrees F.
1/4 Throttle _____850 - 950 Degrees F.
1/2 Throttle _____950 - 1050 Degrees F.
3/4 Throttle _____1050 - 1100 Degrees F.
Full Throttle _____1100 - 1200 Degrees F.
PRO FLOW
Hope this helps
Shav0
Old Nov 26, 2004 | 07:37 PM
whseddon1's Avatar
thanks website was very helpful i found something on ebay that looks like a volt meter and will the meter u gave work if it isnt started
Old Nov 26, 2004 | 07:38 PM
whseddon1's Avatar
sorry i guess not if it measures the temp. how can i check if it isnt started
Shav0's Avatar
No you have to have the quad running. You drive it and watch the guage and see what it reads. Then you make the necessary adjustments.
Old Nov 26, 2004 | 07:39 PM
Shav0's Avatar
All you can do is start it up and find out.
Old Nov 26, 2004 | 07:41 PM
whseddon1's Avatar
the tester i found on ebay is on this link http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Old Nov 26, 2004 | 08:00 PM
Shav0's Avatar
I have never seen those. I've used a EGT guage many times. Its accurate and reduces alot of the triap and error crap associated with jetting. And as the tempature, altidude, and humidty changes you can see it and make the right changes before it causes problems. But there isn't anything wrong with good ol' plug checks, it just takes a while.
Old Nov 26, 2004 | 08:08 PM
whseddon1's Avatar
thanks i think im gonna go wit the gauge u suggested before
Old Nov 26, 2004 | 08:17 PM
Shav0's Avatar
On furthure inspection, Im not sure if you can use these with liquid cooled engines.
Anyone know?
Kyle5050
Dec 13, 2019 04:25 AM
mtdewmn
Jan 19, 2017 12:13 PM
Aitch
Jul 21, 2015 09:40 PM
Ask the Editor
12
Jul 21, 2015 06:57 AM
Mikea1978
Jul 4, 2015 12:37 PM
