Wolvy Owners I need your help!
I need to order a replacement bolt and I ordered the wrong one. Can someone give me the part# for the bolt located as follows:
Its a crankcase cover bolt on the oil fill side of the machine, it is one of the two shorter length bolts that screw into the rectangular looking shape on the crank case, kind of at your "12:00 o' clock" if you are looking at the engine. I ordered a bolt and it was one of the longer ones, but I can't make out the shorter ones on the fiche's you find online.
Thanks.
Thanks.
Originally posted by: hondaguy2
um try bikebandit.com they have different views of parts and bolts. you should find what you need
Anyone who can get me a part # is the man!
If I read the previous post right, I guess this makes me the man:
These come from Yamaha's Website under Part Catalogs
Item, Part Number, Description, Quantity
21, 95027-06030-00, BOLT- FLANGE, 12
22, 95027-06040-00, BOLT- FLANGE, 2
Order the part number for the Bolt that only uses a quantity of 2....you'll get the right one I would assume.
Good Luck.
Good Luck.
Good Luck.
Good Luck.
Thanks man, that was perfect.
Customer Service #1
05-15-2020 08:46 AM
