HELP !!!! How to remove Pro Flow cage ...
Old Dec 1, 2004 | 12:08 AM
twvette's Avatar
Default HELP !!!! How to remove Pro Flow cage ...
Ok, getting very frustrated ... probably something stupid ... whats the trick to remove the cage from the raptor pro flow filter so I can oil it ????
Old Dec 1, 2004 | 01:25 AM
HughJazz's Avatar
You don't remove the cage if it is a K&N filter you just clean with K&N cleaner and oil it with K&N oil
Old Dec 1, 2004 | 05:16 PM
twvette's Avatar
No, its the foam filter. There is the foam filter that is permanently attached to the gasket and then they slipped a "cage" into both of the intake ports to support the foam filter. This seems kinda stupid but I assume they do this so you dont have to worry about how the foam filter seals up against the gasket. Is this a new design or what ... its seems nearly impossible to pull the cages back out once they are in there !!!
Old Dec 1, 2004 | 09:56 PM
twvette's Avatar
Bump ... can nobody help me with this !!!!!???? Lots have to have the Pro Flow foam ...
Old Dec 1, 2004 | 10:20 PM
twvette's Avatar
Give up ... those cages are not coming out easy ... just went ahead and used a foam spray and made sure to work it into all areas of the filter ...
Old Dec 1, 2004 | 10:26 PM
BigDylan's Avatar
they will come out it just takes some force
also if its brand new a lil wd40 or somethin like that will help
just push from the bottom while spreading the rubber out with your thumbs
i use bel ray filter oil
it is very sticky more so than any spray i have used
Old Dec 2, 2004 | 12:52 AM
ItalianStallion's Avatar
Make sure the inside rim is coated with a light coat of oil...set the filter on the ground and slowly work the cage out of the hole by pushing the rim down around the cage...do one at a tme...i do it all the time...then make sure you have a coat of oil on the rim before you put the cages back in...the oil really helps it slip in and out alot
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
