Raptor top end troubles (decompression)
Old Dec 3, 2004 | 05:36 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Default Raptor top end troubles (decompression)
My one-way bolts sheared while I was going about 40 mph,,,,and one of the bolts got jammed temporarily locking up the motor
I fixed the 1 way trouble,,,,the chain is fine, tensioner was fine, crank gear was fine,,one way gear showed some signs of chewing but was fine.
Valves are in check,,,and i can witness the left exhaust valve decompress slighty after the stroke.
Problem is,,,the starter wont turn the motor,,,unless the choke is on,,,and i give in no throttle (restricting air).
When is does start is has a clack that comes from the top end and if you give it gas,,,,it dies.
Its acting like the decompression isnt working properly.
Has anyone had this problem,,,,did some thing shear,,,,or is the decompression not engaging fully.
Any cam guys out there??
could it be something else?
Old Dec 3, 2004 | 05:42 PM
Jibrille's Avatar
I'm sorry I can't help you, but that thing in your sig is endless fun.
Old Dec 3, 2004 | 06:36 PM
1LeSSRaptor's Avatar
That is still somewhat a sign of the one-way with the clink from the top end. Mine does it too, and it started when the one way started to go out and it is getting worse. The bearing is engaging and when it grabs, the bearing lets go at the top of the compression stroke. Don't hold me to it, but that is what mine is doing and that's what I think is going on. Maybe someone else here has a more definate answer.
Old Dec 3, 2004 | 06:40 PM
344PV's Avatar
is that the original on-way or have you changed it before?
Old Dec 3, 2004 | 09:21 PM
Bing's Avatar
Super Quad Patrol
the 1 way is fine,,,,the bolts that held it to the flywheel sheared
Old Dec 4, 2004 | 04:31 AM
Bigdaddy660R's Avatar
I'm Short and Very Ugly.....
Bing; Have ya taken the cam/vavle cover off and looked inside???? get a hold of Quadpotato @ WSQR he has re-build many of the members Raptor motors...... He fixed/re-build Yodaddys 01 tranny when it gave up....Give him a shout on the WSQR site.......[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 4, 2004 | 05:05 AM
Bing's Avatar
Super Quad Patrol
right on,,,i will
Old Dec 4, 2004 | 11:15 AM
sixsixT's Avatar
It could be that the cam jumped time when things let loose. That's what I would check first.
Old Dec 4, 2004 | 11:43 AM
I Agree.......
Old Dec 4, 2004 | 11:46 AM
SCHOLLE's Avatar
Hasn't given up on the 660 just yet...
Check everything carefully.Mine recently scattered and broke the chain, 2 exhaust rocker arms, camshaft and the rest of the decmop mechanisim is mangeled and gouged the head (the head is ok though)Mine was a result of what looks like the pin that that is pressed into the cam gear sheared and the rest turned loose.My one way did not cause it. I replaced mine with the L&A before the original gave any trouble.Other people have had similar trouble.
