Mixing oil on a Raptor
Old Dec 8, 2004 | 02:01 PM
SmokieDaBear's Avatar
Default Mixing oil on a Raptor
I have 4 stroke motor oil for my Raptor, however they aren't made from the same company..One is Honda & the other is Suzuki..Would it cause any problems if I mixed the two together for a oil change? It's all the same specs.
Old Dec 8, 2004 | 02:27 PM
garyc660R's Avatar
It's not a good idea to combine different oils. Why? Each's chemical breakdown is set up with different ingredients IE friction modifiers, cleaners, etc., and when you combine the different oils neither oil is being used in the intended condition of which it was made. The oils could counteract each other and leave you with a lesser quality oil than the 2 oils you started out with. This is asuming the same company is not making both oils and slapping a honda sticker on one and a Suzuki sticker on the other...LOL. <--that happens to.
Old Dec 8, 2004 | 03:33 PM
tecc77's Avatar
Just to add to that............
When mixing some oils together they can actually become caustic. Which means more damage than good, especially when you add heat. I would recommend that even if you change oils you flush the crankcase with the new oil of your choice. I'm not saying that those to oils would be caustic together, but I don't want to see your next post if you find out they are. Just my 2 cents.
Old Dec 9, 2004 | 09:37 AM
Thanks for the reply!
bmxatv10
Oct 14, 2022 06:23 PM
exmotocrosser
Sep 13, 2019 06:12 AM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
