why put grease fitting in carrier?
Old Sep 10, 2000 | 03:33 AM
bplemmons's Avatar
I've read that that it is a good idea to put a fitting in the axel carrier of the warrior.
I am in the middle of changing out the bearing so I have it all apart and I see that the bearings are sealed and if the axel only contacts the inner race of the bearings what would be the benefit of pumping the carrier full of grease and should there be a bleed off hole too if you do it?
thanks Bill
Old Sep 10, 2000 | 10:05 AM
Tree Farmer's Avatar
I think the idea of a grease fitting in the axle bearing carrier is a way to replenish the grease that evaporates, seeps, and oozes away (these things happen, even though the bearings are "sealed"). Otherwise, the only way to grease the thing is take it down as you've done; not something you'd choose to fill your spare time. All-in-all, I think a grease fitting (Zerk) is a good idea, if you have the ambition to install one now: you could extend the life of your bearings considerably with this maintenance aid.
Tree Farmer
Old Sep 10, 2000 | 11:27 AM
raptoid's Avatar
Tree Farmer is correct. My brother put one on his warrior for that reason, and because of water seeping in.
Old Sep 12, 2000 | 01:39 AM
Jennifer's Avatar
Another good reason for a grease zerk is some folks do not perform regular checks on bearing realted parts. The bearings wear and get hot when they get bad, then they tend to want to seize to the carrier. Next thing you know you are spending and hour beating the bearings out of the carrier. Doesn't take long to zerk it and it can save you some time and headache down the line.
Old Sep 12, 2000 | 11:03 AM
DOO800's Avatar
bplemmons,
Make sure you REMOVE the inner seals on both bearings, if you dont the grease will never get to the actual bearing!!!
DOO800
EIF
Apr 20, 2017 07:15 PM
tysonbully
Sep 28, 2015 02:30 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
bigred20653
Sep 19, 2015 02:11 PM
bmark0610
Sep 7, 2015 09:42 PM
