banshee compression
Old Dec 23, 2004 | 01:08 AM
whseddon1's Avatar
Default banshee compression
i have 120 psi on one cylinder and 130 on the other is this bad and why is it like this i tested it many times and always the same thing
Old Dec 23, 2004 | 05:36 AM
superevil's Avatar
If your carbs arent adjusted where they work together properly,one cylinder will work harder and hotter and wear out faster,it sounds like one side was just running hotter or leaner and wore faster
Old Dec 23, 2004 | 03:46 PM
YamahaAtvFreak's Avatar
yep..
Old Dec 23, 2004 | 07:16 PM
whseddon1's Avatar
makes sense thanks guys should i rebore it or can i wait
Old Dec 23, 2004 | 07:55 PM
86LT250RFatty's Avatar
90Psi is the lowest running compression. you should just clean out the carbs good and you should be fine.
Old Dec 24, 2004 | 01:32 AM
2004LEBANSHEE's Avatar
Rebuild a difference of 10 is time for a rebuild. Or you can wait till it blows up. THat gets $$$$$$$$$$$.
Scooter's Shop
Oct 9, 2015 02:09 PM
CosmoM
Sep 21, 2015 04:57 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
