minimum octane levels for 12.5:1 compression ?
#16
When the Raptor was stock, I ran premium.
When I was a 686, 11:1...I ran premium.
Now that I'm running a 14:1 Ross, I am running straight C16 VP race gas.
With a 12:1 I would run atleast 100octane or above.
#17
You need to run the fuel that will bring you just past the point of detination...Try an 87 and then try an 89...Dyno tests have shown that by reducing the octane level the higher the h.p. Low octane fuel has a higher flash point than high octane fuel....The more compression you have, the less flash point you want because the compression is so high that it hardly takes much to ignite the cyliner....The lower the compression, the higher the flashpoint neccesary to ignite the cylinder[img]i/expressions/face-icon-small-confused.gif[/img]
#19
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Steeldon
Sep 9, 2015 09:38 AM
