Taking out spark arrestor on Raptor 350?
Old 12-24-2004, 07:52 PM
Raptorider05's Avatar
Default Taking out spark arrestor on Raptor 350?
If i do this will it effect my engine any?? Has any one done it?
Old 12-24-2004, 08:08 PM
YFZ660R's Avatar
To ATV Thieves: "Hope you guys flip and die douches!"
It will make your quad louder, some say it will give a really small gain in HP, but I don't lnow. It doesn't hurt your quad in any way.
Old 12-24-2004, 08:58 PM
ok, it doesnt mean i have to Re jet or anything cuz i am thinking of doing it, but wasnt sure? Also any tips on how to do it?
Old 12-24-2004, 10:56 PM
86LT250RFatty's Avatar
no rejetting. Get lots of WD-40 and a lot of muscle....and some plyers..
Old 12-24-2004, 11:24 PM
2FAST4URASS's Avatar
Easyiest way to get it out is to take the little bolt out the bottom and remove the one on the bottom of the pipe and get a pair of vise grips and a rag put the rag on the vise grips endpinch the tip and twist it out if notit will be like lt250 said you will need a he!! of alot of muscle to get it out there in tight good luck. oh yea it does make a difference when its out not alot but you can feel it .
Old 12-25-2004, 08:41 AM
VelociRaptor350's Avatar
Some people think it sounds like crap when you do it, i personnaly did. make sure you cover the tip with something or you will screw it up.
Old 12-25-2004, 04:21 PM
Ok guys i took it out and it sounds awsome. When i was riding it it just started sputtering and died. I couldnt get it started again, and when i did it ran fine for a little and then died again and i cant get it started??
Old 12-25-2004, 04:29 PM
clover's Avatar
I took mine out a little while ago and did real good and sounded good,but it started smoking a little bit,so i put the baffle back in and it doesn't smoke no more.So if you leave yours out you might need to rejet.
Old 12-25-2004, 04:45 PM
how come some people dont have to rejet but yall are saying that i do??
Old 12-25-2004, 10:00 PM
Its cold out now, that alone means you need to rejet
Quick Reply: Taking out spark arrestor on Raptor 350?
