Different Pistons Different Octane??
Old Dec 29, 2004 | 05:09 PM
bluebansh's Avatar
Default Different Pistons Different Octane??
I put the wiseco forged pistons in my bike, eveything seems to be doing good other than when i mash into it, it seems to have a small miss then takes off, but right now i am runnin 87 octane, should i run a different octane now or what??
Old Dec 29, 2004 | 05:24 PM
1LeSSRaptor's Avatar
It depends on the compression and the elevation as to if you have to run a higher octane. I wouldn't run anything less than midgrade in a stock bike and usually the 11:1 and lower can take premium and the 12:1 and higher takes race gas. What is the compression of the piston that was put in it? Also is it stock bore? It doesn't matter, but just wondering.
Old Dec 29, 2004 | 05:27 PM
Whoops, thought you had a raptor. But that is pretty much the case with the banshees too. You should run a higher octane than 87, but I think it's a carb problem. Too lean.
Old Dec 29, 2004 | 07:36 PM
maddog56's Avatar
Your sig says you are running high compression wiseco pistons. Stock the banshee calls for premium 91+ octane. Depending on your compression, altitude, and your local gas octane ratings, you may be able to get away with premium pump gas. But for your setup you should be running at least that, and possibly much more.
Old Dec 29, 2004 | 07:37 PM
Shav0's Avatar
The limit for 91 octane is about 155-160 lbs, anything more and you've found your problem.
Old Dec 30, 2004 | 04:32 AM
bluebansh's Avatar
Thanx guys, ive always ran 87 or 89 octance, and never had a preblem till now, but i will definatly go buy some higher octand tomorrow. and i never knew a stock banshee called for at least 91 octane.
Old Dec 30, 2004 | 05:20 AM
maddog56's Avatar
Check your manual, it should say so there. I also believe there used to be a sticker right on the tank.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 30, 2004 | 06:07 PM
bluebansh's Avatar
there might have been a sticker, cant remember i peeled all them off, but i went this morning and got some 93 octane, filled it up and its ran fine all day now, thanx guys
Old Dec 30, 2004 | 06:47 PM
86LT250RFatty's Avatar
i dont know about the stock bike octane, but with a high compression piston, you need to run premium, 94 over here. I used to run 94 in my rappy, and i switched to 87 and it seems to run better...
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
