need help im clueless
Old Dec 31, 2004 | 12:26 AM
daputz's Avatar
Default need help im clueless
Parking brake switch? try swapping the coils out between the 2 quads and see if that helps.
Old Dec 31, 2004 | 02:44 PM
illluder88's Avatar
parking brake switch is good, i already swapped out coils, still does the same thing. this things got me guys
Old Dec 31, 2004 | 03:03 PM
hondabuster's Avatar
Kill switch, disconnected or on? Tried a new plug? ground wires hooked up, from motor to frame?
Old Dec 31, 2004 | 03:31 PM
garrett5462's Avatar
make sure the throttle saafety switch is connected correctly to the carb.
Old Dec 31, 2004 | 03:32 PM
  #15
make sure the throttle saafety switch is connected correctly to the carb. that will stop the spark if not connected right because i had the same problem
Old Dec 31, 2004 | 07:27 PM
  #16
illluder88's Avatar
kill switch works fine,and is on, key switch works and is on, the tors system has been removed prior to this and ran fine, so theres no throttle pos switch anymore, grounding is all good betweent eh motor and frame, does anyone know of any online repair manuals, stores are all closed here and wont open till monday so i cant get a manual this weekend. im still stumped
Old Dec 31, 2004 | 08:32 PM
  #17
If youre close to a public library, go to the 629 section in non fiction, thats where the repair manuals are. Most of the common atvs are covered.
Old Dec 31, 2004 | 08:38 PM
  #18
Shav0's Avatar
If you pull the spark plug from the engine and hold it to the frame is there any spark there at all?
What are you getting for resistance numbers from the coil on the stator and from the ignition coil? It could be too much resistance caused by a bad connection or a weak ground. It might also be the coil itself mounted on the stator plate. Did you have the flywheel off, or the stator during the rebuild?
Old Dec 31, 2004 | 09:19 PM
  #19
UltimateAussie's Avatar
well i would test to see how many volts and amps i was getting at the spark plug boot and if you arent getting enough youi may have clip a wire when rebuilding it
Frisky2050
Apr 9, 2020 11:19 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
matt2490
Dunes and Dune Machines
11
Oct 30, 2003 08:37 PM
