Getting to pilot jet screw .... popping
Old Dec 30, 2004 | 11:26 PM
twvette's Avatar
Default Getting to pilot jet screw .... popping
I get quite a bit of popping when letting off the throttle. Its not a backfire but it does make a "popping" noise. I think I need to tweak my pilot screw up a bit ... or could it possibly be normal to get this with a CT pipe, pro-flow, and open air box. The reason I am a bit confused is my KFX700 with Alien exhaust periodically backfires when letting off the throttle going down a hill and I am sure it needs a pilot screw tweak but it is much more of a violent noise than what the Raptor does. Could it possibly just be how the CT pipe handles back pressure differences or something simlar ... talking out loud here ...
I didnt do the jetting myself ... so, if the pilot does need adjusted can I get to the screws without taking out the carbs ???
Old Dec 31, 2004 | 04:10 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
It is really hard to get to the screws without removing the carbs,,,,,or burning your fingers.
I just ordered a 'Pilot Screw Adjusting Tool' from MotionPro. towards the bottom of the page It will make things way easier.
Old Jan 6, 2005 | 09:53 PM
twvette's Avatar
So, to clarify, if I order the tool does that then allow me to adjust it without removing the carbs or will I still likely need to remove them ???
Thanks for the help ...
Old Jan 6, 2005 | 09:58 PM
Bing's Avatar
Super Quad Patrol
you will be able to adjust the screws while the bike is running,,,,in seconds
Old Jan 7, 2005 | 02:06 AM
caliraptor's Avatar
How the heck do you get to the pilot screws without removing the carbs? Any pics of how this thing works?
Old Jan 7, 2005 | 02:55 AM
Bing's Avatar
Super Quad Patrol
cali
check out the link earlier
its a 16' screwdriver with a 90 degree at about the last inch
the handle swivels and turns the head
look at the pick
its got an internal shaft that spins
Old Jan 7, 2005 | 02:57 AM
Bing's Avatar
Super Quad Patrol
okay,,,its 110 degrees and 17" ,,,,,,close
2nd from the bottom of the page
Old Jan 7, 2005 | 03:11 AM
2FAST4URASS's Avatar
I allways just used a flat head bit like the kind that goes in a cordless drill or what ever its only like 1/2 inch long and its easy to turn but if your not carefull you can get burned . AND thanks for the help on my carb problem about 2 weeks back BING i finally got it took a whille but yea lol.
Old Jan 7, 2005 | 03:17 AM
Bing's Avatar
Super Quad Patrol
yep
i actually bought a little tool about that size with a little disc about the size of a nickel attached to the bottom. but, like you said,,,,,the burns suck
im done with it,,,,,i bought the tool
Old Jan 7, 2005 | 12:22 PM
garyc660R's Avatar
I bought an equivalent tool a couple years ago. You have to be very careful that the screwdriver head is seated into the pilot jet slot or it's no help.
