blaster problem
Old Dec 31, 2004 | 10:59 AM
garrett5462's Avatar
Default blaster problem
hi, i have a 1999 blaster and if seems to be loosing spark at about half throttle. It will idle and is getting plenty of gas but when u get ovwer half throttle it breaks up and boggs down. Also it will not start easily. when we test the spark plug it seems to be fine. cdi box? mag? coil? anyway to test electrical components?
Old Dec 31, 2004 | 11:28 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
a vom and test the output voltage...
Old Dec 31, 2004 | 11:36 AM
NBake's Avatar
what did ur plug look like when u took it out? after u ran ur bike of course
Old Dec 31, 2004 | 11:44 AM
the plug looked fine when i looked at it after i ran it.
Old Dec 31, 2004 | 01:08 PM
i have a multimeter and i wanted to know what setting u would put it on to test the output voltage( u amps, m amps, ac/dc) also where would i put the elctrodes on to. how much volts should it put out?
Old Dec 31, 2004 | 01:36 PM
VelociRaptor350's Avatar
Volts, and just poke around. No battery is AC if im not mistaken.
Old Dec 31, 2004 | 01:38 PM
thanks for the help
Old Dec 31, 2004 | 02:57 PM
Shav0's Avatar
Have you checked your jetting? If it's bogging at half throttle or so it might be a carb problem, not electrical.
Frisky2050
Apr 9, 2020 11:19 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
joeyupton
Jul 14, 2015 11:51 AM
