Raptor GPS Top Speed Results Are In!!!
#22
#23
I wish the DS rev-limiter wasnt so low at
"7700 rpm" which is what they claim it to be...I have seen a few guys who have the Woods tach on there DS that it kicks in more at like "7200 rpm". Mine did 78 mph in the 1/4 and was all over the rev-limiter just after the 1/8 mile mark bone stock.
#24
Hang on a minute Chris!
Carefully read what's already been said. It does run faster in 5th than 4th. 68.6mph compared to 74.3mph on flat ground.
It seems that it has an rpm limiter that is dependent upon what gear you are in. All it would need is a limiter with an ignition signal (for the rpm input) and a current gear signal for this to work. That would be very simple for Yamaha to have done.
I'll soon post the max speed for each gear, the corresponding rpm, and even the top rpm of 4th and 5th gear with the wheels off the ground. For the last one I'll of course have to hook up a tach but that should be easy enough.
With that info we will have the rest of the story!
![Smile](https://atvconnection.com/forums/images/smilies/smile.gif)
#25
#26
#28
I see now, thanks for correction Wsanders, That's what I get for speed reading.
What about the post stating there is a throttle limiting screw on the thumb throttle? If that is the case, this may be why you haven't seen the limiter in any gear. The carb slide thing might also be it. I remember that my 400EX was noticably faster after my prescribed Valve adjustment, but I think that the dealer may have corrected the false full throttle thing too.
Finally, one piece of good news on getting a Raptor so late, You pro's will have all the bugs worked out of them before I even get to start mine!
Keep up the good work. (Otherwise I think the Honda guys are going to get big heads.....)
CIAO
CIAO
#29
Okay, if it was a sensor picking up readings off of the transmission gears and cutting spark, wouldn't it be reasonable that you could hit peak speed, disengage the clutch, and it still wouldn't rev any higher?
Also, is there any chance that you were riding into the wind going downhill or vice versa?
