Banshee sprockets and chain
Old Jan 5, 2005 | 12:35 AM
screaminjlew's Avatar
Default Banshee sprockets and chain
I purchased a new chain and 2 new sprockets for my banshee last year. I purchased the 13 tooth renthal front,(14 tooth stock) 41 tooth sunstar rear and the stock length DID Atv x-ring chain. Now I am running out of adjustment, If I remove one full link the chain it will be too short....and I don't want to add a half link so, I was thinking of adding one tooth more on the rear too take up the slack. When I put this new setup on my bike I didn't have much adjustment to begin with because of the smaller front sprocket, so if I bump up the rear one tooth will that solve my problem?, I don't mind gearing it down a little more[img]i/expressions/face-icon-small-confused.gif[/img]
Please help[img]i/expressions/face-icon-small-happy.gif[/img]
Jlew
Old Jan 5, 2005 | 07:23 AM
BURKEDADDY's Avatar
you cant add a half of a link. the chain needs a even number of inner and outer links to work.just cutout 2 links, one outer and one inner, that should work fine.
Old Jan 5, 2005 | 07:44 AM
maddog56's Avatar
Usually one tooth up or down on the rear sprocket is enough to take care of that kind of issue. I had to drop from a 41 rear to a 40 on my bike to accommodate this problem. Adding one tooth to yours should take care of it for you.
Burkedaddy, where do you think the term "half-link" originated? There is such a thing...
Old Jan 5, 2005 | 08:01 AM
BURKEDADDY's Avatar
ive never heard of the term half link. so half link is going up or down 1 tooth on the rear sprocket?
Old Jan 5, 2005 | 09:14 AM
DRoCk's Avatar
No, a half link is just that...half of a link. They are basically just a small link.
Old Jan 5, 2005 | 09:29 AM
BURKEDADDY's Avatar
yup i just did some looking around and found some OffSet Half Link forsale.see this is why i come here learn something new all the time[img]i/expressions/face-icon-small-smile.gif[/img]
but i though he was talking about cutting just one inner link or just one outerlink out of the chain. got the wires crossed i guess[img]i/expressions/face-icon-small-cool.gif[/img]
Old Jan 5, 2005 | 10:08 AM
toy4rox's Avatar
1 tooth in frunt is like 2-3 in the rear so 1 tooth in the rear will give little gear change but should give the addjustment you need
Old Jan 5, 2005 | 10:18 PM
Thank you all for you input on this topic I really do appreciate your suggestions! If anyone else has any ideas......please respond
thank you, JLew[img]i/expressions/face-icon-small-cool.gif[/img][img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 7, 2005 | 01:42 AM
If I add one tooth to the rear that should take up the slack but, I am not sure that I want my bike geared that low? I do run 8 paddle haulers 20x10x10 and I am a big guy (280lbs) if I was to go to a 40 tooth front and keep the 13 front could I just remove one complete link from the chain and that would give me more adjustment ? Like I said earlier I am running a stock size chain 104 links, I think that is stock size but, not sure?
I would appreciate all insight on this topic, this site is truly the best one on the web!
thanx,
buddieboy
Dec 9, 2016 05:50 PM
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bmark0610
Sep 7, 2015 09:42 PM
