Top speed for a Yamaha Warrior
Old Jan 19, 2005 | 07:19 PM
  #21
D3athShad0w's Avatar
Default Top speed for a Yamaha Warrior
That all depends on how bad I beat the crap out of it (it is a 4 stroke) & how often you ride - If you don’t beat the living crap out of it expect 3 - 4 years and if you do expect about every 100 hours lol.
Old Jan 19, 2005 | 07:22 PM
  #22
Bosch's Avatar
Originally posted by: Fastblasterboy
How often do u do top ends on warriors. My blaster gets 1 ever year.
I have a 2000 Warrior, piped and jetted. bought it brand new in 2000, and the top end is like new,,,and we do run the s$!t outa it. Keep good clean oil in it, and itll go a long time. Bosch
Old Jan 19, 2005 | 07:32 PM
  #23
Fastblasterboy's Avatar
Is there any way to get some sort of cooling on a warrior? Maby like a fan or some thing? i dunno
Old Jan 19, 2005 | 07:35 PM
  #24
Do what I did - Buy the oil filter enclosure element assembly for a 1995 Big Bear. Then you can either run rubber oil line or steel braided hose to any oil cooler that will fit really. I got a Hayden #401 oil cooler radiator from autozone for 28 bucks. I would not put this on a real close to stock setup - you can under cool your oil also...
Old Jan 19, 2005 | 07:37 PM
  #25
where would you put it? The oil cooler assembly
Old Jan 19, 2005 | 07:42 PM
  #26
the radiator goes under the nose and makes the front plastic fake intake fins functional & the element assembly bolts right over where your oil filter case cap is.
Old Jan 19, 2005 | 11:30 PM
  #27
Do you have make special brackets for the oil cooler radiator?
Old Jan 19, 2005 | 11:31 PM
  #28
Speedy2222's Avatar
Is A Power Sport Junkie!
idk here's the site [img]i/expressions/face-icon-small-smile.gif[/img] HERE!!!
Old Jan 20, 2005 | 01:04 AM
  #29
Boxhead's Avatar
Nylon zip ties will hold the cooler perfectly depending on which cooler you install. Permacool makes one that fits between the frontmost plastic brackets and the headlights. I chose that one so it would be tilted more vertically for the air current and would still fit nicely under the hood. The permacool costs a little more but it's very convenient, and does one hell of a cooling job for the size of it. As soon as you install a pipe/air kit it's a good idea to install it.
Old Jan 20, 2005 | 01:12 AM
  #30
JakalWarrior's Avatar
I guess I know where to find the crazy people if I ever want to test my top speed. Ive had to many times I thought I was going to die to ring any bike out past 70 anymore. Maybe im just getting to old. If you really want to go fast though, you shouldnt be looking at spending a few grand modifying a warrior engine...... You need a banshee. Spend a few grand on a banshee motor and it will make you **** yourself till you get used to it.
