What are the best mods for Cross Country Racing?
Originally posted by: Playmaker
Got a yfz450. I'm wondering if I should extend both the a arms and the rear axle. If so, do you think 2 inches on both makes sense or should I go more?
and for cross country you are going to want bottom to mid range power, so i'd look into stuff that will give you that, cross country is alot rougher than most people think and in most cases is worse than racing motocross, you almost have to be in tip top shape to run XC and XC races are pretty long so you'll be running for a while, this is just what i know from experience
The November issue of Dirt Wheels did a story on Bill Ballance's cross country YFZ vs Jeremiah Jones MX YFZ. It talks about the two different motors/bore kits and the different ways the to quads ride. It does talk about Ballance's mods, even gives his jetting specs. Very interesting article.
#15
Great, thanks guys. I'm trying to figure out what set up I want. It would be interesting to know what Bill Ballance's set up is?
good luck
09-23-2015 06:23 AM
