Exhaust
Yeah stubby you have twist, thumb, and an accel pump. The twist throttle kits to go with the carb are good and if you want a twist throttle by all means go for it, the accelerator pump is very nice to have but that carb is a little pricey for what it is. Honestly I dont like that carb because u cant get it in anything bigger then 36mm > A 38mm or even a 40mm depending on your mods such as the Keihin PE or PWK/Qwiksilver Edelbrock/ or even the 38mm Mikuni carb kit offered by powroll would be my choice for the Warrior. However you lose velocity as the carb gets bigger so depending on how you ride and how your motor is what governs the application.
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
