Blaster Carb leak
Old Jan 20, 2005 | 07:26 PM
Camarothatcould's Avatar
Default Blaster Carb leak
Got my Blaster out today to ride and enjoy the 4 inches outside. I started it up, as usual hard time idling and staying started. I look at the drain hose from the bell and noticed there was gas pouring out from there. So I let it warm up and took off. Stopped about 5 mins later and nothing was leaking at all. Anybody know whats up?
Old Jan 22, 2005 | 07:09 PM
garrett5462's Avatar
was it leaking out when the quad was idleing (or close to) or reved up? was ur gas shutoff on off befor you took it out?
Old Jan 23, 2005 | 03:34 AM
Blaster96's Avatar
That was a sign that your float bowl was over filled. Mine does this sometimes. I have concluded that there is more vaccum than nessasary placed on the Carb at idle causing it to drink more fuel.
Old Jan 23, 2005 | 12:45 PM
D3athShad0w's Avatar
If it does it no matter what your floats may be getting stuck.
Old Jan 23, 2005 | 01:13 PM
I had the fuel off, than turned it on n it started leaking so I ran it for awhile than it stopped.
Old Jan 23, 2005 | 01:15 PM
TheWeedman's Avatar
I had the same problem, i got some clamps to stop that, works perfect. and sweet Iroc.
Old Jan 23, 2005 | 02:38 PM
I just put gasket sealer in my other carb and it stopped it. Didnt have a negative effect at all, so, probably try it on this one too. thanks for the compliments on my my ROC.
Frisky2050
Apr 9, 2020 11:19 AM
GregM
Mar 6, 2018 06:53 AM
joeyupton
Jul 14, 2015 11:51 AM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
