Warn 424 Select for a Wolverine
Old Jan 20, 2005 | 08:03 PM
95Wolverine's Avatar
Default Warn 424 Select for a Wolverine
I did some quick searches and didn't find exactly what I am looking for. I recently acquired a 424 for my Wolveirne, but as luck would have it, no install instructions, no anti-rotation hardware, and no **** mounting tab. The mountin tab and anti-rotation hardware I can fabricate, but I would like to have a copy of the orignial installation instructions as I have read there are some adjustments to the control ****.
If anyone can help me out, it would be most appreciated.
Old Jan 20, 2005 | 09:48 PM
LotusPosition's Avatar
PM me your email address and I will scan some copies of mine.
As far as the mounting strap goes, it is total junk IMO. I fabbed my own rubber mounted attachment kit, the original is now an arm's throw away.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 20, 2005 | 09:49 PM
OhHell's Avatar
There is an adjustment on the **** but its no more complicated that adjusting a clutch lever or something simular. It just adjusts the cable pull.
Old Jan 21, 2005 | 01:00 PM
Hotrodhoodlum's Avatar
I drilled a hole in the downtube to mount my anti-rotate strap,,then doubled the strap. I have had no problems with this. The clamp they supplied was puke. I didnt use the bracket to mount the ****, I drilled a hole int eh front fender beside the tank and ran it up through , the fender is the mount, works great and almost looks factory.. the units are great..
Old Sep 1, 2005 | 11:14 PM
Quadusmaximus's Avatar
hey lotus position, could you give me details on how you made
your own anti-rotation strap?
How much clearance do you have between the warn 424 body and the head pipe??
Mines hitting the head pipe!
Thanks
96' wolverine
warn winch
a few mods and improvements
Old Sep 2, 2005 | 12:01 PM
95wolv's Avatar
Quadusmaximus,
I had problems with pipe clearance on my 95 Wolverine when installing the Warn 424, I ended up loosening the head pipe at the motor, and the clamp to the muffler, I was then able to move the pipe around and gain some clearance, not much, but it won't hit now, but still gets hot after a long run, I was thinking of putting some heat relfective tape or an aluminum plate over it to protect it, that heat can't be good for the lube inside the unit, in my opinion.
Old Sep 2, 2005 | 12:32 PM
95wolv
Thanks for the info. Are you using the same anti-rotation hardware
that came with the kit? What I,ve noticed is that the rubber strap becomes
too flexible with heat from the engine allowing the 424 unit to move too much.
96' wolverine
warn winch
Jeff Roper
Feb 1, 2022 11:48 AM
panicmanic
Sep 28, 2015 12:59 PM
carid
Sep 14, 2015 03:40 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
