Warrior clutch problem
Old Jan 22, 2005 | 04:14 PM
recon99's Avatar
Default Warrior clutch problem
Today I was riding my 01 warrior in the snow for a couple hours, and then let it sit outside for a while. When I came out first it seemed like the clutch cable was frozen, then it released, but would not return for a while. Eventually the clutch lever began to move freely, but now it won't go anywhere. If i let the clutch out in gear and pick up the back end the tires spin, but that's all it will do. Anybody know of anything I can do or what the problem might be?
Old Jan 22, 2005 | 04:58 PM
Trasher's Avatar
maybe the cable is frozen. Bring it in and check it out after it thaws out
Old Jan 22, 2005 | 08:59 PM
recon99's Avatar
It's not the cable, because the lever thing that's on the side of the motor moves all the way like it normally does. After it sits in the cold it freezes up again, and it takes a hard pull to break it loose.
Old Jan 22, 2005 | 11:04 PM
recon99's Avatar
I was considering it could be broken clutch spring, but i don't know enough about this to say. I need some input here if anyone has an idea
skinnyr6
Aug 25, 2023 02:18 AM
Reactant
Mar 30, 2022 02:08 AM
honda71
Jul 12, 2015 05:56 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
