changing hubs on a blaster
Most of the Yamaha's sport line up use the same bolt pattern for the front, 4/156. So changing the front hubs is pointless.
The rears on the other hand are one of a kind. Most companies don't make alot of rim choices for 8" rims so it makes your choices limited when looking for rims and tires. Any hub from yamaha's sport line up (donno about utility) will work giving you a different bolt pattern, which interns allows you to use a 9" rim, giving you alot more rim/tire choices.
blueandy88
08-30-2015 08:26 PM
