atv tach
Old Feb 8, 2005 | 12:31 AM
willicub4udk's Avatar
Default atv tach
are there any tachs that are not the tiny tach style? if so,where to get them?
Old Feb 8, 2005 | 12:45 AM
CTracingraptor's Avatar
Default atv tach
do a search and youll find previous post about this subject, im not even going to waste my time. Ron woods for one, plan on spending $200 for any tach for your bike.
Old Feb 8, 2005 | 09:42 AM
maddog56's Avatar
Default atv tach
Nice info, but Ron woods doesnt carry them any more...
Pretty much your only choice for analog is a jr. dragster tach from autometer which only goes up to 10k rpm. If you want digital there are plenty of choices and you can search to find those.
Old Feb 8, 2005 | 09:49 AM
Rider1169's Avatar
Default atv tach
can you use a cheap tachometer from an auto sore? its designed for a car but will it work the same?
----Rider1169
Old Feb 8, 2005 | 10:34 AM
fastblaster00's Avatar
Default atv tach
i started a thread on this a while ago. heres the link
atv tach
Old Feb 8, 2005 | 11:56 AM
86LT250RFatty's Avatar
Default atv tach
im interested in this topic too, because when i go to Aids Auto, i see decent looking tach's for about 50$, the needle type. i think i need a Dyna Ignition to hook it up though..
Old Feb 8, 2005 | 12:10 PM
maddog56's Avatar
Default atv tach
The pulse rate on the dyna ignition is 2 pps which is compatible with most tachs designed for 2-4-6-8 cylinder configurations. Thats why you can use the cheap autozone tachs for them. If you install a tach not set for a 1 cylinder configuration and the correct pulse rate then you will get incorrect readings from the tach if it works at all on a stock coil.
I have been unable to find the pulse rate of the stock coil.
Old Feb 8, 2005 | 07:02 PM
Default atv tach
The thing that matters most on a ATV tach is the delay.
Old Feb 8, 2005 | 08:10 PM
maddog56's Avatar
Default atv tach
Yep, I believe that is called the pulse rate.[img]i/expressions/face-icon-small-wink.gif[/img]
Logan Collins
Sep 5, 2015 08:03 PM
cody500ho
14
Aug 14, 2015 05:03 PM
Charles Gordon
Jun 30, 2015 09:32 AM
tomtcat
Aug 20, 2005 02:02 PM
bigblock
Dec 19, 2001 01:11 AM
