Carb Help?
Old Feb 9, 2005 | 01:53 AM
BarryC's Avatar
Default Carb Help?
Having a problem with idle on a Yamaha 225 4 stroke. When started it idles fine. After warming up, the idle drops and if I don't keep reving, it stalls. Any ideas on what is causing this?
BC
Old Feb 9, 2005 | 08:39 AM
sixsixT's Avatar
Default Carb Help?
Are you using the choke to start it?
Old Feb 9, 2005 | 05:36 PM
hondabuster's Avatar
Default Carb Help?
Usually, if it starts and runs fine, cold, and the problems happen after its warmed up...its probably too rich. Check the mixture screw, it may be too rich, or the float level may be too high, or the choke may be sticking partially on.
Old Feb 10, 2005 | 10:43 AM
renegade888's Avatar
Default Carb Help?
Also want to check your valve adjustment. As the engine heats up the exhaust valve especially will expand a bit and maybe beyond the recommended valve lash setting.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
