Tight Clutch lever on Raptor
Old Feb 9, 2005 | 05:15 PM
Martino's Avatar
Default Tight Clutch lever on Raptor
For some reason my clutch lever has been a little harder to pull in than normal and just want some way to make it easier to pull in suggestions???? p.s. the clutch is on a 01' 660 THKS
Old Feb 9, 2005 | 05:20 PM
Boxhead's Avatar
Try spraying wd40 in both ends of the cable, and if that doen't work try buying a new cable. If that still doesn't work try a universal ez pull clutch lever made from a honda cr lever, the better ones are with a sealed bearing.
Old Feb 10, 2005 | 04:02 PM
Martino's Avatar
thks man Ill try that wd40 hope it does the trick and hopelly wont have to buy a new cable
Old Feb 10, 2005 | 06:01 PM
Boxhead's Avatar
The wd40 trick worked well on my warrior's cable when I sunk it sideways in 3ft of muddy water. It's cheap and comes in a big can so you can use a large qty to flush any debris out. New cables are usually $10 to $13, so it won't be much of a loss.
Old Mar 23, 2005 | 11:46 AM
cruiser3's Avatar
Is the freeplay adjusted properly?
Old Mar 24, 2005 | 03:53 PM
Martino's Avatar
Well the free play was adjust properly and after changing the clutch cable the Clutch itself went out shortly thereafter and so I replaced it with the that GYR-T Racing Clutch and everything seems to be working correctly thanks for all the input
-Chris
STLyamwar
Jul 25, 2020 04:44 AM
Cummins Driver
Sep 11, 2019 01:22 PM
Ashley S
Aug 6, 2015 12:56 PM
Polarisman1123
Aug 3, 2015 02:08 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
