hard to shift!!!
Old Feb 13, 2005 | 08:29 PM
YFZ450Hornet's Avatar
Default hard to shift!!!
Is it stated in the owners manual? If not I would just look around on the shifter and i am sure you will answer your own question. Good luck
Raptorboy4life's Avatar
switch the teeth on the shift dowel pin. Would you rather fall wit sneekers or boots? If its hard to shift then learn.. not hard for me to shift with boots!
Old Feb 13, 2005 | 08:36 PM
Boxhead's Avatar
Your lever should be adjustable, and a good trick is simply to have really good boots. The alpine tech 4's will let you pivot your foot vertically enough to shift very comfortably while not letting it pivot sideways at all. A friend of mine got some cheaper thor boots and they were too stiff to do sh*t in them, even after they were broke in, really makes a big difference to have a good pair.
Old Feb 13, 2005 | 08:57 PM
2phast4u's Avatar
i got some thor boots i love them u just gotta break them in and yeah lifting yur lever would help but i dont mind i usally just get into 2nd or 3rd and not shift at all unless im dragging ill just stay in a mid range gear sumtimes if im messin around ill bump it to 4th but im mostly in 3rd but when i start racing ill deff move the shift up
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
Elkaholic
Sep 6, 2015 02:44 PM
