Banshee 300FT Drag??
Old Feb 14, 2005 | 01:16 PM
bluebansh's Avatar
Default Banshee 300FT Drag??
Well im not much of a drag racer, i just dont get a rush out of a straight line shot, But hey im curious of what the ol Bansh will do, i was thinkin this, about a 12 tooth front sprocket and a set of 18 inch rear tires. Anyone have any clue bout what it would run and is the sprocket and tires the best choice for a 300ft drag, thats bout the only two things i thought i could change to get torque, plus i just wanna try it once so i dont wanna spend all kinds of money for just a one time fun deal.
Old Feb 14, 2005 | 02:43 PM
enFORCER's Avatar
Wow, that is some low gearing..... You better make sure you start in 3rd gear.... I will be running 22" tires, and my gearing will be 16-40...... [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 14, 2005 | 03:27 PM
Yamaha660R's Avatar
I would think you would want to gear up some..and run some type of good tire for dirt drags. I would think you should run somewhere around 5.6+ in 300ft.
Old Feb 14, 2005 | 03:39 PM
Bubba297's Avatar
Bluebansh, you make very good torque with the FMF pipes and the single carb. The top end power will suffer slightly as a result, and the last thing you want to do is gear it down a lot. On most light modded Banshees we change out the rear sprocket from a 41 to a 42 and that's it. Enforcer will be making some big HP, so that is the reason for his tall gearing.
Kaleb_00
Jun 1, 2016 09:15 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Jul 7, 2015 11:00 PM
