Need help adjusting the steering????
Old Feb 16, 2005 | 10:58 AM
Martino's Avatar
Default Need help adjusting the steering????
My raptor's steering as of late has about 1/4 to 1/2 an inch of play so I was wondering how to make it tight again...It has been suggested that I repack tha bearings however I could use a little input on how to fix it Thks for any suggestions or opinions
Old Feb 16, 2005 | 08:10 PM
RacerRob's Avatar
This is an easy fix. The problem is the nut that holds the tie-rod mounting bracket to the steering stem comes loose time and time again. All you need to do is take off the nut, coat the threads with Lock-Tite, then wrench the nut back on.
I had the same problem, but after doing the trick with the Lock-Tite, it hasn't come loose yet!!!![img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img]
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
