help sons Raptor 350
I bought my sos a Raptor 350 It seems to run fine, however if you rev it up a little while it is parked it will cough and sputer like it is running lean I checked the spark plug and it is white. Im wondering what I should do next Please help...
make sure the gas is on reserve cause that kinnda thing happened to me. The reserve level is real high on them. The motors are like the same as warriors and there know for reliablity so its probably not a big problem.
Thanks, Ill check that, I think it is a fuel problem because while it was just seting there at idel I turned the fuel valve off and after a fue minuts it started caughing just like befor and Im wondering about the white plug?
Never mind, Either you guy's are jacken around are you yamerheads are dum__ses.I thought there may be a commen problem with the Raptor 350 you know like all the commen problem that the 660 has.No the parking brake is not engaged, and no im not looking at the proclen insulator im talking about electtrode and post the part that goes inside the engin. Thanks anyway
what octane are you running in it? Mine does that when i run super, it dosn't need it because the compression is so low, throw some regular gas in there and it should clear right up.
