need help jetting a blaster
Old Feb 23, 2005 | 03:29 AM
INDIANLARRY's Avatar
Default need help jetting a blaster
I was thinking of just making my life easy and buying dial a jet but was told by several people not to do it, so my question is can anybody tell me what I should jet at ? its a 2004 yamaha blaster with the following mods
28mm carb
v force reeds
reed spacer
key adv
k & n
open lid
fmf silencer with fatty pipe
lightned flywheel .............................. thanks for the help
Old Feb 23, 2005 | 06:07 AM
2fun's Avatar
Try a 280-290 main jet, and drop the clip on the needle one position. See if that helps.
We had a similar set-up on our Blaster, and these settings worked pretty good for it.
Old Feb 23, 2005 | 12:10 PM
fastblaster00's Avatar
i have the dynojet kit and im runnin a 360 jet
Old Feb 23, 2005 | 04:02 PM
Bubba297's Avatar
dynojet jets are smaller than OEM jets. You usually end up with a larger number in those.
BTW, is it a Mikuni or a Keihin?
Old Feb 23, 2005 | 04:48 PM
Shav0's Avatar
We can't say what sizes unless we know what kind of carb is on it. With a mikuni it would be around the 300 some where, but with Keihin you will be in the 150 range.
BTW, the dial-a-jet still requires you to have jets that are close to perfect, usually one or two sizes smaller is what they reccommend.
Old Feb 23, 2005 | 06:11 PM
2fun's Avatar
Well, I'm afraid someone else is going to have to help you then.
I have no idea how a dynojet # compares to a Mikuni #.......
If in fact you are using a stock Blaster carb. (Mikuni)
Old Feb 23, 2005 | 11:09 PM
i have a stock carb. teh dyno jet kit said wiht none- mild engine mods and aftermarket exhuast and no air box lid to run the 360 main jet taht they give u adn put in the needle with the clip on the 3rd spot down. thats what im doin and its runnin prtty good. when the weather gets getter im gona exparement with different jet sizes and perfect it a lil more.
Old Feb 26, 2005 | 03:57 PM
its a 28mm cpw carb, i bought it on ebay, it says it uses all kelhin carb replacement parts, so the name on the carb says cpw ( carberator parts warehouse) it looks like they put their name on a carb....maybe you have heard of this carb ?
Old Mar 12, 2005 | 12:40 AM
anymore ideas on where to start on the jetting ? im gonna install it all tomorrow so more infor would be nice, thanks for the help
ReconBayou
Oct 31, 2022 05:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
nastyblaster100
Sep 13, 2015 01:19 PM
