Need Help Jetting messed up!
Make sure your fuel line is on the right input. there is also a breather hose that is located close to the gas hose and if the gas hose is hooked up to this, then the carb will just fill up with gas and over flow through the over flow hose. Check this first and if it is not the answer then the float hieght is wrong, stuck, or the needle isn't closing properly. good luck
