Winch maintenance
Old Feb 23, 2005 | 11:51 PM
Grandmama's Avatar
Default Winch maintenance
Does anyone know what the best lubrication is when cleaning and maintaining an atv winch? Mine was long overdue and I want to get it as waterproof and worryfree as possible before re-installing.
Old Feb 24, 2005 | 03:33 PM
GrizzlyFD's Avatar
Silicone...or you can unwind the winch and use a light engine oil/grease on the cable. I spray mine a couple times a year. Just make sure the cable is dry and free of dirt/debris before you lubricate it. A power washer will save you a tremendous headache not having to unwind the entire spool.
Old Feb 24, 2005 | 05:54 PM
Grandmama's Avatar
thanks for the cable advice, but what i really need is the best lube for the internal gears- i.e. the planetary gear sets.--i'm assuming it's some sort of heavier grease. i'm going to use a general multi-purpose grease if nobody tells me differently or has a better suggestion-- thanks,
Old Feb 24, 2005 | 09:33 PM
trailcrawler's Avatar
everyone has their own ideas, on my winch i disassemble spool off the drive/planetary gears,check for water, and dirt, if not any i use silicone based grease add a light coat to everything and reassemble, if there is dirt- wash in solvent or saftey clean, dry then gease it all down and reassemble with extra grease on gears after each stepp....i also use morreys oil stabilizer as a extra measure, add a thin coat all over during reassembly. it is synthetic and nearly water proof....hope this helps don't forget the bearings of the spool and the freewheel disengage
Johnny Mac
Aug 15, 2019 03:13 PM
dannytas
Sep 26, 2017 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
caveeagle
Sep 19, 2015 01:20 PM
chewy78
Sep 8, 2015 10:37 AM
