sprocket for banshee????
Old Feb 24, 2005 | 11:34 PM
julikikas's Avatar
Default sprocket for banshee????
i need help on buying a set of sprocket for my banshee. Would i need to buy both or just one? I like to drag alot so would like to go with that set up. How many teeth would i need and how would the bike run when i'm trailing? thanks!!!
Old Feb 25, 2005 | 12:12 AM
NastyNate03's Avatar
depends what you want do you want it for mostly drags or trails you can do 1 or both remember its a give and take situation higher top speed decreases acceleration
Old Feb 25, 2005 | 01:25 AM
julikikas's Avatar
for drags, how many teeth would i need on my sprocket?
Old Feb 25, 2005 | 06:22 AM
2FAST4URASS's Avatar
I may be wrong but i think stock is 13/38 so if you just want to blast out of the hole use a 12/40 set up but that will put a big damper on top end but you will take off like a bat out of hell.But also you would be doing alot of shifting due to the short gearing.
buddieboy
Dec 9, 2016 05:50 PM
Kaleb_00
Jun 1, 2016 09:15 AM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Jul 7, 2015 11:00 PM
