Raptor Cam and sprockets
Old Mar 11, 2005 | 07:11 PM
Blkjaxx's Avatar
Default Raptor Cam and sprockets
Hey guys, I'm about ready to put in my stage 1 HC and have some questions on sprocket sizing. I have a 12/41 combination I am wanting to try out but wondering if it would be to wheelie happy with my current setup (Full Exhaust, Pro-flow, jetted). I do mostly tight wooded trail riding, but don't want to have to worry about keeping the front end down all the time.
Are any of you guys running this setup or having any advice?
Old Mar 12, 2005 | 01:55 PM
Blkjaxx's Avatar
Any suggestions guys?
Old Mar 12, 2005 | 02:03 PM
344PV's Avatar
the 12/41 should work fine. i run that but i ride in the dunes
Old Mar 12, 2005 | 06:38 PM
Blkjaxx's Avatar
Thanks for the info 344, I am going to put them on and see what it's like.
Old Mar 12, 2005 | 06:48 PM
86LT250RFatty's Avatar
well since you geared it down, and its allready wheelie happy at stock, its going to be even more wheelie happy.. ist 13/40 Stock gearing? so 12/41 it will want to come up even more..
Old Mar 12, 2005 | 07:50 PM
Blkjaxx's Avatar
I am wanting to try and eliminate the gap between first and second. Right now, in the really tight trails I have to be in first alot becauseit tends to bog in 2nd. I want to be able to be in 2nd and 3rd more of the time. I realize that gearing down makes it more prone to wheelies however I need the upper gears to be a bit shorter.
Old Mar 12, 2005 | 08:41 PM
UBETRUN's Avatar
With 22" rear Holeshot XCT tires, I ran 12/44 on the trails. 1st gear was useless but 2nd and 3rd were perfect and it was easy to lift the front end over mud, creeks, brush, etc.
Old Mar 12, 2005 | 08:45 PM
raptoric's Avatar
12/41 is some low gearing. probably why your wheeling so much.
hot cam stage 1 is more of a low end cam so it will want to wheelie even more.
try the 12/40 with the stage 1 cam, im running this end it has great power and no noticable gaps between gears
Old Mar 12, 2005 | 11:51 PM
Blkjaxx's Avatar
Thanks for all the info guys. I will give 12/40 a try before going to a 41 rear.
bmxatv10
Oct 14, 2022 06:23 PM
buddieboy
Dec 9, 2016 05:50 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
