Best steering stem for Raptor?
Old Mar 12, 2005 | 02:56 PM
jcdraptor's Avatar
Default Best steering stem for Raptor?
Crashed the other day and bent the stem, what is the best stem to replace it with? I have the tag 2 handlebars. Is there anything else I'll have to change?
Old Mar 12, 2005 | 03:31 PM
LivinInVegas's Avatar
My wife did the same thing on her Raptor. We got her a Lonestar stem with the anti-vibe clamp, (you need the clamp) they clamp comes in standard and 1-1/8 for fat bars. You may want to buy a new top clamp for the lights and the key as the Lonestar clamp does'nt provide any light or key holes. you can use your Tag top clamp but then you have a black top clamp and a chrome bottom clamp. (if it matters) I would recommend the +1 stem over the standard if you have a real low rise bar set-up. I got the best price at Ronnie's (300.00 with the anti-vibe clamp) but that was last year so look around. You won't need anything else except patients because you have to remove the gas tank to get to the bolt on the upper stem column. Good luck!
Old Mar 12, 2005 | 04:37 PM
Turbo33's Avatar
Check into the Janssen. They have really great stuff and they are priced right 920-766-3411
tell them Quinn told you to call.
Old Mar 12, 2005 | 10:48 PM
BigDylan's Avatar
i have a lonestar and im very happy with it also check roll design,gibson,rpm, or houser
Old Mar 13, 2005 | 02:39 PM
jcdraptor's Avatar
Thank you for the replies
Old Mar 13, 2005 | 02:55 PM
jcdraptor's Avatar
The tag handle bars I have came with a clamp that has the holes in it, will it work with the lonestar stem?
Old Mar 13, 2005 | 08:39 PM
RAPTORAZ's Avatar
The only bad part about using a stronger than stock steering stem is that the frame bends instead of the steering stem when you crash. I've seen it happen to two of my buddies. I went back to using a stocker after that. I'd rather replace the stocker(which are less than $100) more often , then have to straighten the frame after a good rollover.
Old Mar 14, 2005 | 10:55 AM
CTracingraptor's Avatar
I agree with raptoraz, ive seen this happen also. The same thing goes for the bars. For instance if you buy a nice set of bars that are hard to bend..Renthals, if and when you wreck your not going to bend the bars but you'll end up bending the sterring stem. Ive wrecked twice on my renthals, both times i bent the steering stem, and the renthals were not touched. my advice get teh stocker for east coast atv.
Old Mar 14, 2005 | 12:22 PM
RaptorOwner's Avatar
I got a new stock stem from my local dealer for 89.00 + tax. Better than 300.00 and a bent frame....
Old Mar 14, 2005 | 08:25 PM
BigDylan's Avatar
no if you get a lonestar stem you wont need the clamps anymore you just use the clamp that comes with the stem but be sure to get the mount for oversized bars
also i like the anti vibe alot better than the stocker if you are worried about a bent frame then you should gusset it for strength
i plan on gusseting mine sometime this summer when i take it apart to powdercoat it
bmxatv10
Oct 14, 2022 06:23 PM
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
black_thunder
Sep 22, 2015 07:59 PM
