430 big bore kit for warrior
Old Mar 12, 2005 | 06:36 PM
96warriormod's Avatar
Default 430 big bore kit for warrior
what do you guys think of Powroll's 430 big bore kit . i already have a 20 over kit in right now and its not enough
Old Mar 13, 2005 | 02:00 AM
yamahawarriormods's Avatar
what up austin......
Old Mar 13, 2005 | 11:34 AM
DeathShadow's Avatar
Honestly you should look into Intake and exhaust before going the 430 way. .430 cam & springs, Race Port & Polish w/3 angle VJ, better carburetor, better intake (pro design), 1mm Oversized valves, good pipe, etc... Mod the quads ability to breathe first then go big bore. As far as the kit I have heard many good things about it; the bad things ive heard are from people that went the cheap way and did not go with a stronger rod or better bearings... HotRods also has recently come out with a stroker crank, Rod (Hotrods), & High comp piston kit for 4-500$ & no core charge; keep your old crank and sell it!! The cam alone should put a smile on your face [img]i/expressions/face-icon-small-smile.gif[/img]!
*Stick an oil cooler on that bike ASAP!!
Old Mar 13, 2005 | 12:56 PM
ZillaRider87's Avatar
the kit im guessing is a bore/stroke kit. but what do you mean the 20 over kit. its bored 20 over? cuz thats not a kit for power.........
Old Mar 13, 2005 | 05:42 PM
he meant its already been bored 20 over its got a hot cam and a wiesco piston jet kit and supertrapp exhaust... although he knows the piston is and sleeve is gon with the kit but whats some info on big bore kits for the warrior
Old Mar 13, 2005 | 09:49 PM
SCHOLLE's Avatar
Hasn't given up on the 660 just yet...
http://www.fourstroketech.net/
I have seen warriors built by them. They run great!
Barnsnelbon
Sep 27, 2015 03:07 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
