nitrous or powroll 430 kit for warrior
Old Mar 12, 2005 | 09:56 PM
96warriormod's Avatar
Default nitrous or powroll 430 kit for warrior
let me reword this ... i cant decide between a Boondockers system or the powroll 430 big bore kit . what are pros cons...what do you thinkl?
Old Mar 12, 2005 | 10:49 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
run a 365kit with the boondockers kit and cam and Port and Polish it...
Old Mar 12, 2005 | 10:50 PM
Speedy2222's Avatar
also.. on a side note... Have you thoghut of maybe putting a turbo on it instead?
Old Mar 12, 2005 | 10:52 PM
poopy's Avatar
yea a 430 kit will could cause a lot of trouble down the road. and i heard a good port and polish could do wonders.
Old Mar 13, 2005 | 01:04 AM
DeathShadow's Avatar
A 430 kit is just fine if done right (better bearings new stronger rod etc...) HotRods came out with a stroker crank, rod, and piston kit for the warrior and its only like $400.00!!! I would go with a wet system I researched Nitrous systems alot for my warrior and it is way better to go wet with a fuel pump. Go with a high comp piston, oversized valves, .430 midrange cam w/springs, port & polish, Qwiksilver Edelbrock carb, a good pipe, an oil cooler setup, & Pro Design intake. I would not run nitrous with to many stock parts...
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
