warrior help
Old Mar 15, 2005 | 12:29 AM
titty's Avatar
Default warrior help
i have a 87 warrior it has a 20 over piston and has a stock pipe and a kn filter and holes in air box what should i jet it at i live in the boston aera it pops when its cold when i give it gas but when it warms up it runs great what do i do????????????
Old Mar 15, 2005 | 12:38 AM
yamahawarriormods's Avatar
i would half to reccomend a jet kit they are very help full un less some one on here knows what get to use
Old Mar 15, 2005 | 07:26 AM
NLWarrior01's Avatar
Have you checked you plug color? That will be one indicator of if you need to rejet, though it sounds like you do. As a good start, I would purchse a 155 main jet, and then also get one above and one below size. So that would be 152.5, 155 and 157.5
I found that with my uni filter and FMF pipe my pilot is too lean even with the box cover on. With the trails we have around here I don't often spend a lot of time past 1/4 throttle or so .. just little blips. I did have a 160 main jet installed, but that was too rich even with the box cover off. So I have a 155 now, which I plan to install sometime in the next 5 to 10 years .. or whenever I get time at it [img]i/expressions/face-icon-small-happy.gif[/img]
Good luck in the mean time!!
Old Mar 15, 2005 | 08:22 PM
KILLEREX's Avatar
burn it!!
Old Mar 15, 2005 | 08:43 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
stock pipe *wtf face* you know... you're NOT suppose to drink the bong water...
Old Mar 18, 2005 | 01:42 AM
gordichuk's Avatar
change the jetting to a 50.1
Old Mar 21, 2005 | 06:33 PM
KILLEREX's Avatar
did it burn good????
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
