valve ticking after cam install?
Old Mar 19, 2005 | 01:09 AM
raptoric's Avatar
Default valve ticking after cam install?
ive read that it is pretty normal with the stage 2, but how about with
the stage 1? ive just had 11:1 piston and stage 1 cam put in and it ticks pretty
loud at idle.
Old Mar 19, 2005 | 01:15 AM
XR650Warrior's Avatar
what's the valve lash specs. ?
Old Mar 19, 2005 | 01:59 AM
400exKiller990's Avatar
i thought that too.. i can here mine tick alll the time but was its normal. its a very good thing, if your kept stock valve springs, to check your valve lash every 3-6 months or so just to be safe so far so good on mine. good luck
Old Mar 19, 2005 | 12:51 PM
HughJazz's Avatar
Make sure you didn't put you cam in a half turn out. It cause the decompresion pin to stay sticking out
Old Mar 19, 2005 | 02:13 PM
blingbling's Avatar
would it run with the cam 1/2 turn out?
Old Mar 19, 2005 | 02:46 PM
no it would prolly fail...
Old Mar 19, 2005 | 02:58 PM
HughJazz's Avatar
Yes it will run with the cam a 1/2 turn out. The engine turns over 2 for every one turn of the cam. If it didn't have a decompression pin it would matter if it was a half turn out. I did this on my raptor.
Old Mar 19, 2005 | 04:53 PM
how would you notice this difference ? what would it do?
Old Mar 19, 2005 | 07:29 PM
warrior007's Avatar
Even if the cam were 180 out it is really the decompression mechanism that you are talking about, it will work even if the cam is 180 out (and its right according to the cam, even though the cam is wrong). It wont work if the decompression cam inside the real cam is 180 out (from the cam).
The decompression mechanism pushes a tiny pin out of the cam to release some of the compression during starting, after the motor is started weights on the cam gear let the decomp mech push the pin back in and stay inside the cam until they are needed again. Sometimes you will hear a knock when shutting off the motor because of these wieghts swinging back and catching the decomp mech.
If you install the decomp mech 180 out (according to the cam) it will be engaged all the time, eventually wearing the pin off or breaking it altogether. The motor wont run too bad however you will have a lot of valve train noise. The internal pin cam that the decomp mech works on only 1/4 turn, if you have it 180 out the whole backside of it is round with no inverse lobe to let the pin push in to.
[img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 19, 2005 | 09:38 PM
maddog56's Avatar
The valve specs are .006 and .008 for the HC stage 1 or 2. There will be more valve noise, but if it doesnt decrease when you readjust the lash and if its really really loud, I'd bet its the decompression mechanism. I had mine installed backwards, not a good thing and the bike ran bad.
