K&N with no lid??? need jetting??
Old Mar 20, 2005 | 12:57 PM
yrrej's Avatar
Default K&N with no lid??? need jetting??
ok im running my quad rightnow with the k&N with no lid on it and its running rich........should i just put the 240 jet in........is there nething else i have to adust after that?
Old Mar 20, 2005 | 01:17 PM
skramblr's Avatar
No mention on what type of bike you have?
If you added the K&N and removed the lid - AND you are still running the original jetting - You should be running LEAN, not rich. More flow = more air = less gas in that air = lean = go larger jet size.
Old Mar 20, 2005 | 02:49 PM
yrrej's Avatar
yeah sorry its a blaster............idk the spark plug was charcole black..........but wen i jet it and i take out my carb .....there is a little gray plastic peice that leades to the air mix screw and a box thing under the seat and i dont know how to take that off the top of the carb
Old Mar 20, 2005 | 02:52 PM
yamaharaptor350's Avatar
are ya runnin the quad on super unleded gas cause that can make your spark plug black... and it will give your motor tons of carbon biuld up cause it has low compression
Old Mar 20, 2005 | 02:53 PM
yrrej's Avatar
just regular........thats the one i fill my tank up with regular
Old Mar 20, 2005 | 07:09 PM
yam05yfz's Avatar
why do u fill up with regualar use premium i think all motorcycles or quads should run on that i even run my lil xr50 on that
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
