Warrior Spitting and Splatering when i Gas it
HI all.I have a ?.I need a little help.about 5 weeks ago i was out mudd bogging with quad had a blast.We rode a mudd hole all day,later that day my quad started to bog spitter when i tried to hit high RPM's If it just sat and idle it was fine but as soon as i got on the throttle it would bog down.I have it jetted and run a pro circuit exhaust.What should i do?I put a new sparkplug tried to adjust idle screw but it still spits and splatters. [img]i/expressions/face-icon-small-confused.gif[/img]
could be your parking brake, when the wires on it dont connect or somthuing it will make you quad bogg when you gas it , or might have **** in your carb, ied clean it if i were you
i think i have the same problem or something similar but my quad revs hi then makes like a clacking sound then revs low and does it over and over (in idle). when im going it does the some thing but dont rev low what could be the problem.
