Sprocket change s for Warriors
Old Mar 30, 2005 | 10:09 PM
GOHARD's Avatar
Default Sprocket change s for Warriors
What is the stock sprocket tooth numbers(1994)?
Could i get a set of sprockets to get it to run around 65 mph +
Right now just has a fmf pipe and k & n filter.
Thanks
Old Mar 30, 2005 | 10:41 PM
bberck's Avatar
sprocket sizes should be 13 40 stock at least are for mine dont think they changed them. And considering a stock warrior should run 60 or so a 15 tooth front sprocket should get you close.
Old Mar 30, 2005 | 10:49 PM
2strokegood89's Avatar
well you could just not be lazy and count the teeth on the darn thing
Old Mar 31, 2005 | 06:28 PM
GOHARD's Avatar
Yea i did count it but i new the guy i bought it from said he chnged it.
Has a 15 in front and 40 in rear and only does 60 mph.Where s the speed going.Has stock tire size on it.
Old Mar 31, 2005 | 06:37 PM
VelociRaptor350's Avatar
you know there's a 6th gear, right? im j/k
Idk man, you should eb able to go faster then that.
Old Mar 31, 2005 | 06:39 PM
GOHARD's Avatar
Thats what i thougt i better take another look at that front sprocket.
If nothing changes would the next thing be to change the back and if so to what?
Thnaks
Old Mar 31, 2005 | 06:49 PM
bberck's Avatar
Should run faster but being a 94 could have some engine wear thats losing you some speed
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Jason Campbell
Sep 7, 2015 02:25 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
Elkaholic
Sep 6, 2015 02:44 PM
