grizzly rev limiter
Old 04-02-2005, 12:06 AM
mnausa's Avatar
Default grizzly rev limiter
when i go up hills on my '02 grizzly it starts spitting and sputtering but will not go dead. i have been told that it might be the rev limiter. how can i fix this? please help!!
Old 04-02-2005, 12:48 AM
kawzukicatguy's Avatar
Float setting maybe. Did it always do it or start suddenly?
Old 04-02-2005, 12:59 AM
mnausa's Avatar
did it always
Old 04-02-2005, 01:01 AM
mnausa's Avatar
the yamaha shop put the new vent covers, gas tank and heat sheild on and said that it should fix the problem, but it didn't
Old 04-02-2005, 01:05 AM
mnausa's Avatar
the tech at the shop said "if it was the float it would do it even under normal driving conditions"
it runs fine except when i put it in a bind like going up hill.
Old 04-02-2005, 01:33 AM
In my unproffesional opinion I still say float. The tech at the shop is wrong. My grizz got hot enough to sputter several times during a ride, it doesn't matter if your on flat ground or a hill with that problem. If your float was out of adjustment, it could very possibly give you problems only on hills.
If anybody thinks differently, please add your thoughts.
Old 04-02-2005, 01:50 AM
hondabuster's Avatar
If its totally stock...air filter, exhaust, clutching..then its not the rev limiter. A stock grizzly wont hit the rev limiter in high, the clutching wont let it.
My best guess would be the float is too low, or the air box lid is off, or the intake has a leak.
If you pull on the choke, when it sputters...will it get better or worse? or no difference.
Old 04-02-2005, 02:02 AM
mnausa's Avatar
have not tried the clutch, will try it tomorrow, thanks guys
Old 04-02-2005, 09:40 PM
batmanacw's Avatar
If it is lean it will sputter when you ask for power. I would try putting tape partially over the snorkle and see if that helps. If it does, then I would look into rejetting. What Throttle position does it happen in? I could also be the float out of postion. You should also check for air leaks around the carb. I will sometimes spray a little starting fluid lightly around the carb while it is running. If it is sucking air, it will affect the idle speed when it whiffs some ether.
DGNAZ
ATV Expeditions
06-22-2017 04:20 PM
cboler9
09-24-2015 08:35 PM
TLC
Utility ATVs
09-16-2015 01:41 PM
Steeldon
09-09-2015 09:38 AM
Steeldon
Utility ATVs
09-05-2015 09:38 PM
Quick Reply: grizzly rev limiter
