Hot cam in 660R __ Ned Help !!!!!!!
Old Apr 3, 2005 | 06:36 PM
Joe00's Avatar
Default Hot cam in 660R __ Ned Help !!!!!!!
I just put a STAGE 1 Hot Cam in my 2004 660R. It fires up and seems to run great for a bout 20 Sec. and then the exhaust pips right off of the head start to get so hot they glow!!! Any idea????
Old Apr 3, 2005 | 07:10 PM
QuadN00b's Avatar
I'm pretty sure that means you're running lean, but don't take my word alone on the matter.
Old Apr 3, 2005 | 10:00 PM
86LT250RFatty's Avatar
yup your running lean, does it do this why'll idleing? or riding? what other mods do you have? Try going up to a 25 Piolit jet, or just turn the air screews out a turn. also, bump up your main jet a size on each carb
Old Apr 3, 2005 | 10:34 PM
Joe00's Avatar
WOW, That is a relief. I thought I screwed something up. I've installed the cam twice now because it did this the first time and I thought I screwed up the motor. Im running a proflow intake and the stock muffler. The cam is the only other mod. It sounds like I need to give the motor more fuel, right??
Old Apr 4, 2005 | 01:37 AM
raptor010's Avatar
Have some questions. What does a pilot jet, main jet, and needle all do? Heck my pipes are always glowing. Maybe I should change somethings up. I have changed them all out but just don't really know what they do. I forget things easily.
Old Apr 4, 2005 | 08:13 PM
Joe00's Avatar
I spoke with a cople of shops in my area to day and spoke with HotCams and they all say that a little glowing is normal but going up to a larger main jet will lower my exhaust temps a little. And help give it a little more power. I still need to install a after market exhaust. any I deas on whtch one is the best for a good price
Old Apr 4, 2005 | 08:22 PM
go with a yoshi from rockymountainatv, 396$ shipped.
Old Apr 4, 2005 | 08:27 PM
Joe00's Avatar
Is That just The muffler or is that a hole kit?? Heads and mid Pipe to
Old Apr 4, 2005 | 09:14 PM
ItalianStallion's Avatar
Try turning out your air fuel screws a 1/4 turn at a time...That should help alot. and put a good pipe and header on it. It'll make a big difference.I like Sparks and CT Racing myself but Yoshi is ok I guess.
Old Apr 4, 2005 | 11:54 PM
Joe00's Avatar
Thanks for the help, I turned out my fuel / air screws about a half a turn and that helped. the pipes dont get as hot. And now I'm off to find a new exhaust tomarrow, any thing at this point has got to flow better than the stock one. Thanks for the help.
blpersinger
Jul 15, 2015 09:56 PM
AtvManiac78
Jul 11, 2015 03:20 AM
Kain
Dec 19, 2004 07:47 PM
Kain
Dec 21, 2002 04:45 AM
Sylvain97378
Apr 10, 2002 12:13 AM
